gorden
#1 Posted : Monday, August 30, 2010 12:04:49 PM(UTC)
gorden
Two inches of ice sitting in the bottom of the freezer, some of it thaws, leaks onto the floor. the freezer freezes food very hard and i cant turn it down. whats my fridges problem?
#2 Posted : Monday, August 30, 2010 6:16:02 PM(UTC)
The ice on the freezer floor means the drain under the evaporator in the freezer is clogged and/or frozen.
Remove the rear panel in the freezer and defrost the drain, using a hair dryer. Run hot water through the drain to make sure it's open. A turkey baster might help. Pool the refrigerator out of the wall and make sure the other end of the drain is open as well. It is a good time to clean the condenser.
Wait about 24 hours after it's done and measure the temperature in both compartments. Post the results.
gorden
#3 Posted : Wednesday, September 1, 2010 5:32:23 PM(UTC)
gorden
Glen, you nailed it.
somehow the little tin tray that catches the run off water got bent, instead of the water running through the down spout a good part of it was running down the side collecting at the bottom of the freezer.
The down spout that runs to the collection tray was clogged as well.
I dragged my little compressor in and blew everything out. I took your advice and gave it the turkey baster test. everything over the last 24hours seems to be in order.
I have the freezer on 1. the lowest setting and it seems to me like its too cold??? I don't have a thermometer to read the temp.
Thanks for the assistance, i'm sure you saved me the service call. :)
#4 Posted : Friday, September 3, 2010 2:50:53 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Any ice cream in the freezer is a good temperature indicator. If it's not too hard or too soft, the temperature is fine.
inqfinance
#5 Posted : Sunday, September 5, 2010 8:08:24 AM(UTC)
inqfinance
I have the same issue. When you say the evaporator coil, where do I find it and also, where do I find the defroster?
What is turkey baster?
#6 Posted : Monday, September 6, 2010 2:06:10 PM(UTC)
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 3/15/2024 12:21:35 PM(UTC)
Kenmore Side by Side Warm (Refrigerator & Freezer Repair)
by Lery 6/10/2020 7:14:50 PM(UTC)
Kenmore side by side ice maker problem (Refrigerator & Freezer Repair)
by DIY987 8/11/2019 3:11:25 PM(UTC)
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 2/21/2019 7:14:22 PM(UTC)
1970's Kenmore Side by side...constantly running (Refrigerator & Freezer Repair)
by silvering 7/20/2017 3:34:13 AM(UTC)
Kenmore Side by Side Freezer Leaking (Refrigerator & Freezer Repair)
by rkirkwo1 10/3/2016 10:27:43 AM(UTC)
Kenmore Side by Side Frost Buildup (Refrigerator & Freezer Repair)
by metolius22 7/27/2015 7:30:58 PM(UTC)
Kenmore Side By Side Fridge Warm Freezer Good (Refrigerator & Freezer Repair)
by craig72 7/15/2015 9:23:52 AM(UTC)
Kenmore side by side won't get cold (Refrigerator & Freezer Repair)
by hprambo 9/15/2014 11:58:15 AM(UTC)
kenmore side by side not defrosting (Refrigerator & Freezer Repair)
by john 10512 6/3/2014 9:36:51 AM(UTC)
Kenmore side by side freezing food (Refrigerator & Freezer Repair)
by Felony 12/3/2013 8:29:13 PM(UTC)
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11/16/2013 5:36:27 AM(UTC)
Kenmore side by side freezer not freezing (Refrigerator & Freezer Repair)
by Handy handy 6/22/2013 3:03:37 AM(UTC)
Kenmore side by side freezing up (Refrigerator & Freezer Repair)
by BaileyH 6/11/2013 1:07:53 PM(UTC)
Kenmore side by side (Refrigerator & Freezer Repair)
by Rtazz17 3/16/2013 5:10:15 PM(UTC)
