lyle w. royal
#1 Posted : Wednesday, July 30, 2008 2:19:20 PM(UTC)
lyle w. royal
My wife says the large burner on her electric stove gets too hot. Does the burner stay in the high posltion all the time when the switch is in the high position or should it go in a lower heat?
SublimeMasterJW
#2 Posted : Wednesday, July 30, 2008 2:23:44 PM(UTC)
SublimeMasterJW
If the burner stays wide open all the time then the switch is bad. It's tiny little contacts are welded together and dreaming of their next burnt shrimp creole meltdown. Replace that switch.
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
GE Electric Range - nothing heats (oven or burners) (Oven Repair (including Ranges and Cooktops))
by tgtn7723 11/29/2020 5:29:31 AM(UTC)
GE Electric Range not maintaining temperature. (Oven Repair (including Ranges and Cooktops))
by Flicker87 11/24/2015 7:53:57 PM(UTC)
Really old GE electric range... HELP (Oven Repair (including Ranges and Cooktops))
by pinkimarie 12/3/2013 2:27:48 PM(UTC)
GE Electric Range, Oven (Oven Repair (including Ranges and Cooktops))
by Hanne555 4/28/2013 5:24:50 AM(UTC)
GE Electric Range - Display/oven clicks, cuts on and off. (Oven Repair (including Ranges and Cooktops))
by GeorgePo 12/27/2012 3:17:30 PM(UTC)
GE electric range top shorted out (Oven Repair (including Ranges and Cooktops))
by brizander 9/12/2012 2:22:52 PM(UTC)
1960's GE Electric Range 4-connector elements (Oven Repair (including Ranges and Cooktops))
by billca 8/13/2012 12:55:44 PM(UTC)
GE electric range (Oven Repair (including Ranges and Cooktops))
by CHIEF1096 9/2/2011 11:24:56 AM(UTC)
ge electric range (Oven Repair (including Ranges and Cooktops))
by linda kolonsky 7/28/2011 4:46:24 PM(UTC)
GE Electric Range Part (Oven Repair (including Ranges and Cooktops))
by MDHome 1/29/2011 7:28:10 AM(UTC)
GE Electric Range won't get hot unless you turn it way up (Oven Repair (including Ranges and Cooktops))
by axrowland 1/10/2010 7:46:45 PM(UTC)
Replacing insulation in GE electric range/oven (Oven Repair (including Ranges and Cooktops))
by JudgeHooke 1/4/2010 1:23:24 PM(UTC)
GE electric range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by Arnie 3/18/2009 8:38:23 AM(UTC)
