I have a whirlpool gr440lxmb0 electric range. The front right burner won't heat up unless I turn it up to 7. It then gets very hot but under that it seems to heat incredibly slow. Is this the infinite switch or the burner?
THIS FORUM IS DEAD!!!!!!! |
I have the parts list, I need an opinion based on the issue as to which part I should replace the infinite switch or the burner?
Sorry I missed the last line of that post. I will try the switch.
