CHIEF1096
#1 Posted : Friday, September 2, 2011 11:24:56 AM(UTC)
CHIEF1096
range door wont open after self cleaning
Joe / APP Team
#2 Posted : Friday, September 2, 2011 1:31:11 PM(UTC)
Joe / APP Team
Chief,
That unit has a "mechanical latch"
The handle could be loose or bent, or the thermal latch lock has failed in the locked position.
Part number: AP3140305
You could manually unlock the door using a coat hanger(straighten it out put a large hook in one end, insert it between the top of the door, and pull the hanger from right to left once the hook engages the latch hook on the mechanism, press in on the top of the door and tug on the hanger(it only takes 1/4 to 1/2 inch to release) and open the door. You'll need to raise the cooktop to access and remove or replace the latch assembly.
GE Electric Range not maintaining temperature. (Oven Repair (including Ranges and Cooktops))
by Flicker87 11/24/2015 7:53:57 PM(UTC)
Really old GE electric range... HELP (Oven Repair (including Ranges and Cooktops))
by pinkimarie 12/3/2013 2:27:48 PM(UTC)
GE Electric Range, Oven (Oven Repair (including Ranges and Cooktops))
by Hanne555 4/28/2013 5:24:50 AM(UTC)
GE Electric Range - Display/oven clicks, cuts on and off. (Oven Repair (including Ranges and Cooktops))
by GeorgePo 12/27/2012 3:17:30 PM(UTC)
GE electric range top shorted out (Oven Repair (including Ranges and Cooktops))
by brizander 9/12/2012 2:22:52 PM(UTC)
1960's GE Electric Range 4-connector elements (Oven Repair (including Ranges and Cooktops))
by billca 8/13/2012 12:55:44 PM(UTC)
ge electric range (Oven Repair (including Ranges and Cooktops))
by linda kolonsky 7/28/2011 4:46:24 PM(UTC)
GE Electric Range Part (Oven Repair (including Ranges and Cooktops))
by MDHome 1/29/2011 7:28:10 AM(UTC)
GE Electric Range won't get hot unless you turn it way up (Oven Repair (including Ranges and Cooktops))
by axrowland 1/10/2010 7:46:45 PM(UTC)
Replacing insulation in GE electric range/oven (Oven Repair (including Ranges and Cooktops))
by JudgeHooke 1/4/2010 1:23:24 PM(UTC)
GE electric range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by Arnie 3/18/2009 8:38:23 AM(UTC)
GE Electric Range (Oven Repair (including Ranges and Cooktops))
by DRWALLIE 3/15/2009 6:20:28 PM(UTC)
by lyle w. royal 7/30/2008 2:19:20 PM(UTC)
