We've had this range about 5 years. I noticed about 2 weeks ago that the display would randomly go off and the clock would be running slow. Last week while using the oven, it kept clicking and the display would turn off and then back on. Now, it seems to just keep clicking over and over and the oven won't come up to temp. I am guessing there is some kind of relay issue with the control panel...it's trying to kick on...but can't. The burners work fine. Is my assumption correct? If I just replace the control board, should this fix my issue? Any help is very much appreciated. Thanks!
Hello George,
You are on the right track. The correction is to replace the control board. I would recommend to order the new overlay too because it's adhered to the control board. If you need the correct part numbers, post the end of the model number.
