hi i have a kenmore upright freezer that doesnt freeze the compressor is hot and stays on light works in freezer jumped the t stat and still not getting cold m# 25321111103 cannot see any other controls on it like defrost timer it doesnot have any fans either was working fine now no freezing any help please
the freezer shelves are also the evaporator coils. are they all iced up or is there one without frost on it. Or do they all have way too much ice buildup.
Originally Posted by: woodchuckie  the freezer shelves are also the evaporator coils. are they all iced up or is there one without frost on it. Or do they all have way too much ice buildup. there is no frost or ice build up compressor turns on but no cooling happens or freezing
I believe you have a compressor problem or no freon. These problems require a qualified tech to service.
Originally Posted by: woodchuckie  I believe you have a compressor problem or no freon. These problems require a qualified tech to service. i will try to put freon and hope it works otherwise i will trashit cause comp a little to expensive
Originally Posted by: manduxe  i will try to put freon and hope it works otherwise i will trashit cause comp a little to expensive put refrigerant in and now works fine just just dont want to unplugg the freezer because i think it has a small leak so i guesss i have to keep freezer on so refrigerant wont leak out again im guessing if i keep the freezer on the freezer wont thaw out and start leaking again probably the wromg thing to do any suggestions thanks
