manduxe
#1 Posted : Saturday, June 20, 2009 5:22:00 PM(UTC)
manduxe
hi i have a kenmore upright freezer that doesnt freeze the compressor is hot and stays on light works in freezer jumped the t stat and still not getting cold m# 25321111103 cannot see any other controls on it like defrost timer it doesnot have any fans either was working fine now no freezing any help please
woodchuckie
#2 Posted : Saturday, June 20, 2009 5:43:19 PM(UTC)
woodchuckie
the freezer shelves are also the evaporator coils. are they all iced up or is there one without frost on it. Or do they all have way too much ice buildup.
manduxe
#3 Posted : Saturday, June 20, 2009 5:51:28 PM(UTC)
manduxe
there is no frost or ice build up compressor turns on but no cooling happens or freezing
manduxe
#4 Posted : Sunday, June 21, 2009 1:34:22 PM(UTC)
manduxe
can anyone help
woodchuckie
#5 Posted : Sunday, June 21, 2009 8:45:53 PM(UTC)
woodchuckie
I believe you have a compressor problem or no freon. These problems require a qualified tech to service.
manduxe
#6 Posted : Monday, June 22, 2009 7:14:49 AM(UTC)
manduxe
i will try to put freon and hope it works otherwise i will trashit cause comp a little to expensive
manduxe
#7 Posted : Friday, September 4, 2009 9:27:30 AM(UTC)
manduxe
put refrigerant in and now works fine just just dont want to unplugg the freezer because i think it has a small leak so i guesss i have to keep freezer on so refrigerant wont leak out again im guessing if i keep the freezer on the freezer wont thaw out and start leaking again probably the wromg thing to do any suggestions thanks
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
SidexSide Fridge/Freezer not cold; tried to self-diagnose (Refrigerator & Freezer Repair)
by kenroehr 2/1/2018 6:10:10 AM(UTC)
Refrigerator & Freezer Not Cold - Evap Coils Frosted Over (Refrigerator & Freezer Repair)
by gciccol 12/13/2017 1:32:46 PM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 4:38:01 AM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
