edmiller
#1 Posted : Thursday, September 1, 2016 8:32:25 AM(UTC)
edmiller
I just checked the temp in my freezer and it sits at 25 degrees, which is probably not low enough. I hear the compressor running, so it should be OK.
Can someone give me some hints where to start looking?
Thanks,
Ed
cbmserviceguy
#2 Posted : Thursday, September 1, 2016 9:01:09 AM(UTC)
cbmserviceguy
Make sure the evaporator fan (inside the freezer behind the back cover) and the condenser fan (bottom of unit in back by compressor) are both running when the compressor is running. Check to make sure your condenser coils (under/behind unit) are clean, free of pet hair/dust and can have air moved over them freely. Let us know what you find when you check those items please. Thanks!
edmiller
#3 Posted : Thursday, September 1, 2016 10:41:33 AM(UTC)
edmiller
Thanks for the fast response.
Both fans run and the coils seem to be pretty clean. In the meantime the temp has been going lower, it's at about 10 degrees now. I'll watch it until tomorrow morning.
Thanks,
Ed
edmiller
#4 Posted : Friday, September 2, 2016 7:11:27 AM(UTC)
edmiller
Last night it was down to Zero but this morning it's back up to 15 degrees. It seems to be fluctuating quite a bit.
Any suggestions?
Thanks,
Ed
cbmserviceguy
#5 Posted : Friday, September 2, 2016 7:21:11 AM(UTC)
cbmserviceguy
Sounds like an airflow issue to me. Take a look at the back wall of the freezer and see if there is any visible frost. If there is, even just a little, take it apart and pull the back cover off to expose the evaporator. See if it's all plugged up with frost. If it is, manually advance the defrost timer until it clicks into defrost and compressor shuts off. Wait a few minutes and see if it starts thawing the frost around the heater on the evaporator. If it does, you need a new defrost timer. If it does not, you will need to ohm out the defrost t-stat and heater to determine which is no good. Either way, after you determine the issue, you can thaw the frost and unit will work fine for a week or so until you get parts in it.
edmiller
#6 Posted : Friday, September 2, 2016 8:02:16 AM(UTC)
edmiller
I had the unit off the wall yesterday and there was no frost on the back wall at all. But I guess I could open that back wall and check things.
Just checked the back wall again. No frost and it can't be taken off anyway.
There are only two lengthy pieces of metal but they are just covering a bunch of cables. No evaporator to expose.
#7 Posted : Friday, September 2, 2016 12:36:13 PM(UTC)
You did not get the previous advice right. cbmserviceguy meant the rear wall inside the freezer. Please, check this wall and post the results.
cbmserviceguy
#8 Posted : Friday, September 2, 2016 12:49:17 PM(UTC)
cbmserviceguy
Gene is correct. I mean to check inside the freezer at the very back. If there is a defrost problem the evaporator will be solid with frost and air will not be able to properly circulate. This would cause the issues you are describing. Let us know what you find. I'll try and pop on later and see what you came up with.
edmiller
#9 Posted : Saturday, September 3, 2016 11:35:20 AM(UTC)
edmiller
Sorry, I misunderstood that.
I'll check and let you know.
Thanks guys.
Ed
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 9/24/2015 9:57:47 AM(UTC)
by billpulsipher@gmail.com 8/28/2015 11:25:19 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 8/6/2015 2:05:17 PM(UTC)
by Suzalasue 5/28/2015 6:08:45 AM(UTC)
by wnorton 1/27/2015 3:21:20 PM(UTC)
Freezer not cold enough, fridge working (Refrigerator & Freezer Repair)
by JDM1oc 12/4/2014 8:36:25 PM(UTC)
