Both fans are working. Compressor is humming and very hot to the touch. Attached is pic of evaporator coils. Neither freezer or frig are getting cold enough. Thank you! themayhews attached the following image(s):
Looks like a sealed system problem. This would be an expensive repair and often it makes more sense to put the dollars towards a new unit. Below is a link, take a look at the three example pictures about a third of the way down the page. http://www.applianceaid.com/ref...ator-not-cold-enough.phpJust to be sure you may want to defrost the unit and then let it start up again. After half an hour or so ogf the compressor running check the evaporator coils again. They should have a fairly even coating of frost. If not then it is a sealed system problem for sure. |
THIS FORUM IS DEAD!!!!!!! |
