Suzalasue
#1 Posted : 10 years ago
Suzalasue
Three year old fridge. Freezer not very cold. Compressor is running but not keeping stuff frozen. Refrigerator is cold. Ice is ok but most other stuff is soft. Repairman came,took off back panel in freezer said u need a new compressor!!!! He didn't check anything else. Put the cover back and charged $90. I think we need another opinion but $90 a shot is crazy. Can this really be the problem in a fridge that 's only 3 years old? Thanks.
#2 Posted : 10 years ago
You are missing 8 digits of the model number.
Is the compressor running?
You can usually hear it but should also feel it vibrating.
If running does it run all the time except when the unt goes through a defrost cycle?
Are the condenser/compressor fan and the evaporator/freezer fan running?
Are the condenser coils clean?
Are the vent at the front and back of the unit clean?
If the compressor is running remove the cover in the freezer and check the evaporator coils. Be sure the compressor has run for about an hour before doing this. If you do it during or shortly after a defrost cycle you may end up with the wrong diagnosis.
If heavily iced/frosted over you may have a defrost problem.
If there is just frost in one are or no frost then it is a sealed system problem. This will be an expensive repair. Check your warranty often the sealed system has a longer warranty.
If the compressor is cycling OK then it could be a temperature regulation problem. May just need a new thermostat.
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 3 years ago
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 4 years ago
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 4 years ago
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 5 years ago
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 6 years ago
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8 years ago
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 8 years ago
by projvw18t 8 years ago
by edmiller 9 years ago
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 10 years ago
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 10 years ago
by billpulsipher@gmail.com 10 years ago
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 10 years ago
by wnorton 10 years ago
Freezer not cold enough, fridge working (Refrigerator & Freezer Repair)
by JDM1oc 10 years ago
