manduxe
#1 Posted : 16 years ago
manduxe
hi i have a kenmore upright freezer that doesnt freeze the compressor is hot and stays on light works in freezer jumped the t stat and still not getting cold m# 25321111103 cannot see any other controls on it like defrost timer it doesnot have any fans either was working fine now no freezing any help please
woodchuckie
#2 Posted : 16 years ago
woodchuckie
the freezer shelves are also the evaporator coils. are they all iced up or is there one without frost on it. Or do they all have way too much ice buildup.
manduxe
#3 Posted : 16 years ago
manduxe
there is no frost or ice build up compressor turns on but no cooling happens or freezing
manduxe
#4 Posted : 16 years ago
manduxe
can anyone help
woodchuckie
#5 Posted : 16 years ago
woodchuckie
I believe you have a compressor problem or no freon. These problems require a qualified tech to service.
manduxe
#6 Posted : 16 years ago
manduxe
i will try to put freon and hope it works otherwise i will trashit cause comp a little to expensive
manduxe
#7 Posted : 16 years ago
manduxe
put refrigerant in and now works fine just just dont want to unplugg the freezer because i think it has a small leak so i guesss i have to keep freezer on so refrigerant wont leak out again im guessing if i keep the freezer on the freezer wont thaw out and start leaking again probably the wromg thing to do any suggestions thanks
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 3 years ago
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 3 years ago
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 4 years ago
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 4 years ago
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 5 years ago
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 5 years ago
SidexSide Fridge/Freezer not cold; tried to self-diagnose (Refrigerator & Freezer Repair)
by kenroehr 7 years ago
Refrigerator & Freezer Not Cold - Evap Coils Frosted Over (Refrigerator & Freezer Repair)
by gciccol 7 years ago
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8 years ago
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 8 years ago
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 8 years ago
by projvw18t 8 years ago
by edmiller 9 years ago
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 9 years ago
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9 years ago
