modelshop8624
#1 Posted : Sunday, May 17, 2009 7:28:08 PM(UTC)
modelshop8624
I have a Whirlpool washer that leaks only when it is filling the tub. How do you remove the cabinet? Thanks for any help that you can give me.
#2 Posted : Monday, May 18, 2009 4:07:47 PM(UTC)
The first thing I would check is the pump. This is a good time to check the motor coupling and replace it if needed. You can find the instructions attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSN1000KQ0 | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 49 time(s).
How to remove the pump.doc (25kb) downloaded 23 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 19 time(s).
modelshop8624
#3 Posted: : Thursday, May 21, 2009 11:14:30 PM(UTC)
modelshop8624
Thanks for the information. I really appreciate it . Thanks again.
#4 Posted : Saturday, May 23, 2009 8:36:42 PM(UTC)
modelshop8624
#5 Posted : Friday, May 29, 2009 3:31:45 PM(UTC)
modelshop8624
I replaced the pump and just finished washing a load of clothes. I did not notice any leaks. It was not a difficult job. The information that you provided was very helpful.Thanks again.
#6 Posted : Saturday, May 30, 2009 10:15:03 PM(UTC)
We are glad you were able to fix it. Good job!
fredazz
#7 Posted : Monday, June 8, 2009 10:53:03 AM(UTC)
fredazz
i have the same problem. if you get any help, please pass it on to me. thanks
modelshop8624
#8 Posted : Monday, June 8, 2009 9:53:03 PM(UTC)
modelshop8624
I removed the pump and that solved my problem. good luck.
File Attachment(s):
How%20to%20remove%20the%20pump[1].doc (25kb) downloaded 11 time(s).
Guest (5)
Whirlpool washer leaks from front - replaced pump... still leaks! (Washer Repair)
by metadog 2/17/2013 4:34:39 PM(UTC)
whirlpool washer leaks (Washer Repair)
by mdeagan 3/16/2012 1:54:39 PM(UTC)
Whirlpool Washer leaks (Washer Repair)
by Gern Blanston 1/24/2012 8:16:18 AM(UTC)
Whirlpool washer leaks at certain time of cycles (Washer Repair)
by Pegleg37 10/4/2011 10:16:55 AM(UTC)
Whirlpool washer leaks from front while filling (Washer Repair)
by bobandjayne 4/27/2011 12:08:00 PM(UTC)
Whirlpool washer leaks (Washer Repair)
by jstevens 9/19/2009 9:16:54 AM(UTC)
by pritch99 12/10/2008 10:51:19 AM(UTC)
by billmac77 8/5/2008 4:39:07 PM(UTC)
