another mom
#1 Posted : Monday, April 6, 2009 11:05:45 AM(UTC)
another mom
My GE frontloader is acting up. It pumps water out, but doesn't spin. I have cleaned all of the change/baubles from the hose, no difference.Checked the pump, and nothing is in the way. Removed the belt, set the timer to Regular wash, started it, the motor doesn't turn. checked the speed control with a meter, it seems to be ok. How do you check the door lock switch to see if it's out? I know how to remove it, but don't know how to check it, or the timer switch either, which seem to be the only two things left. Any other ideas?
Also, the tech sheet that was in the washer is falling apart, and its hard to read. can you get another copy of it somewhere?
Rhonda
suzanneboggs
#2 Posted : Saturday, May 23, 2009 3:39:17 PM(UTC)
suzanneboggs
sounds like what is wrong w/ our GE Frontloader. Noticed your date is about 6 weeks old. did you ever find out what was wrong w/ it? Ours did the same thing last night. It will spin when we first start the cycle, but that's it.
