I have a Whirlpool washer that leaks only when it is filling the tub. How do you remove the cabinet? Thanks for any help that you can give me.
Thanks for the information. I really appreciate it . Thanks again.
Originally Posted by: Gene You are welcome. Keep us posted.
Gene. I replaced the pump and just finished washing a load of clothes. I did not notice any leaks. It was not a difficult job. The information that you provided was very helpful.Thanks again.
We are glad you were able to fix it. Good job!
You have been a member since:: 6/8/2009(UTC) Posts: 1
i have the same problem. if you get any help, please pass it on to me. thanks Originally Posted by: modelshop8624 I have a Whirlpool washer that leaks only when it is filling the tub. How do you remove the cabinet? Thanks for any help that you can give me.
Originally Posted by: fredazz i have the same problem. if you get any help, please pass it on to me. thanks I removed the pump and that solved my problem. good luck.
