washer seems to be leaking from outside bottom of tub after agitation.does not leak from direct drive pump or hoses.dripping mainly from backside of washer tub.tub seal bad?? hard to change??
More likely to be a split or hole in drain hose. Possibly leaking from water inlet valve.
