pritch99
#1 Posted : Wednesday, December 10, 2008 10:51:19 AM(UTC)
pritch99
washer seems to be leaking from outside bottom of tub after agitation.does not leak from direct drive pump or hoses.dripping mainly from backside of washer tub.tub seal bad?? hard to change??
magician59
#2 Posted : Wednesday, December 10, 2008 12:38:49 PM(UTC)
magician59
More likely to be a split or hole in drain hose. Possibly leaking from water inlet valve.
Whirlpool washer leaks from front - replaced pump... still leaks! (Washer Repair)
by metadog 2/17/2013 4:34:39 PM(UTC)
whirlpool washer leaks (Washer Repair)
by mdeagan 3/16/2012 1:54:39 PM(UTC)
Whirlpool Washer leaks (Washer Repair)
by Gern Blanston 1/24/2012 8:16:18 AM(UTC)
Whirlpool washer leaks at certain time of cycles (Washer Repair)
by Pegleg37 10/4/2011 10:16:55 AM(UTC)
Whirlpool washer leaks from front while filling (Washer Repair)
by bobandjayne 4/27/2011 12:08:00 PM(UTC)
Whirlpool washer leaks (Washer Repair)
by jstevens 9/19/2009 9:16:54 AM(UTC)
by modelshop8624 5/17/2009 7:28:08 PM(UTC)
by billmac77 8/5/2008 4:39:07 PM(UTC)
