2 Pages<12
Noob
#11 Posted : Friday, December 21, 2007 6:26:58 PM(UTC)
Noob
I'm having a similar issue with a Hotpoint model# RGB508ET4WH. The stovetop burners work but when I turn on the over it does not light, I do not hear or smell gas either. Does not appear to have a pilot light.
Any help would be appreciated, I would like to have a baked potato with dinner tommorow. :cool:
#12 Posted : Friday, December 21, 2007 6:43:50 PM(UTC)
Most likely the problem with your oven is a bad igniter (#218 on the #4 break down diagram).
- The part number for the oven igniter is AP2020569
- Here are the break down diagrams for the Hotpoint range Model RGB508ET4WH
Good luck.
Noob
#13 Posted : Friday, December 21, 2007 6:56:27 PM(UTC)
Noob
Thanks for the quick response.
After some searching around I had a feeling it might be the igniter. Hopefully I can find one locally tommorow.
Are they usually brand specific or are they a common part that is interchangable between many ovens?
#14 Posted : Friday, December 21, 2007 7:45:13 PM(UTC)
A flat igniter can be interchange with a flat igniter only. Also the length of the ceramic part is important.
Noob
#15 Posted : Saturday, December 22, 2007 10:05:51 AM(UTC)
Noob
New igniter installed and the thing works!
Thanks again for the tips.
#16 Posted : Saturday, December 22, 2007 12:44:53 PM(UTC)
I'm glad you were able to fix it.
Happy holidays!
georgebwhite
#17 Posted : Sunday, December 23, 2007 8:01:48 PM(UTC)
georgebwhite
Originally Posted by: Clintr Go to Quoted Post
My oven will not light when I turn it on, I do not smell gas so I was wondering if it was the T-Stat for the oven?
my oven will not turn on and i do not smell gas so what is the first thing i should replace?
georgebwhite
#18 Posted : Sunday, December 23, 2007 8:07:45 PM(UTC)
georgebwhite
my oven will not turn on what is the first thing that i should replace?
#19 Posted : Monday, December 24, 2007 8:56:23 AM(UTC)
In order to provide the most accurate advise I need the complete model number of the unit and more specific description of the problem.
Post it as a new thread, please.
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
Oven will not light (Oven Repair (including Ranges and Cooktops))
by easymoney12 9/18/2012 3:49:06 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
2 Pages<12
