I'm having a similar issue with a Hotpoint model# RGB508ET4WH. The stovetop burners work but when I turn on the over it does not light, I do not hear or smell gas either. Does not appear to have a pilot light. Any help would be appreciated, I would like to have a baked potato with dinner tommorow. :cool:
Most likely the problem with your oven is a bad igniter (#218 on the #4 break down diagram). - The part number for the oven igniter is AP2020569 - Here are the break down diagrams for the Hotpoint range Model RGB508ET4WHGood luck. Gene.
Thanks for the quick response. After some searching around I had a feeling it might be the igniter. Hopefully I can find one locally tommorow. Are they usually brand specific or are they a common part that is interchangable between many ovens?
A flat igniter can be interchange with a flat igniter only. Also the length of the ceramic part is important.
New igniter installed and the thing works! Thanks again for the tips.
I'm glad you were able to fix it.
Happy holidays!
Originally Posted by: Clintr  My oven will not light when I turn it on, I do not smell gas so I was wondering if it was the T-Stat for the oven? my oven will not turn on and i do not smell gas so what is the first thing i should replace?
my oven will not turn on what is the first thing that i should replace?
In order to provide the most accurate advise I need the complete model number of the unit and more specific description of the problem.
Post it as a new thread, please.
