Richard Beasley
#1 Posted : Thursday, June 4, 2009 6:36:08 AM(UTC)
Richard Beasley
evap fan is working, condenser fan is working, all coils are clean, no ice build-up, evap and condenser coils are the same temp
compressor cycles on and makes a high pitch sound and than gets very hot before it cycles back off
#2 Posted : Thursday, June 4, 2009 10:40:19 AM(UTC)
Richard,
If the evaporator is not covered with thin snow and the compressor is hot then most likely there is a restriction in the sealed system. It has to be serviced by a certified technician.
Richard Beasley
#3 Posted : Thursday, June 4, 2009 1:42:43 PM(UTC)
Richard Beasley
Thanks for the response, when I got home from work I decided to plug it back in to recheck everything. When I plug the fridge in both fans come on and the compressor comes on for 8 seconds, goes off for about 2 minutes and than on for 8 seconds, off for 2 minutes, over and over and over. The compressor never runs long enough to even get warm. Maybe last night when I thought it was hot it was because it had been running. My wife told me around 7pm it was making a funny noise and that was when I started checking everything out.
Richard Beasley
#4 Posted : Friday, June 5, 2009 1:23:05 PM(UTC)
Richard Beasley
I stopped by an appliance repair shop near work today and the tech told me I needed a starter relay, so I bought one from him, installed it, and I still have the same problem. Is the compressor bad? He also told me $400.00 to replace the compressor, is this correct?
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Fridge and freezer not cooling (Refrigerator & Freezer Repair)
by tommydoggett 4/6/2017 9:39:13 AM(UTC)
Fridge and freezer not cooling temp for both flashing 0 (Refrigerator & Freezer Repair)
by Biggie121 1/25/2016 11:10:41 AM(UTC)
by mousenup2 9/9/2015 5:46:56 AM(UTC)
by Victorgon 3/31/2014 8:16:38 PM(UTC)
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 3/27/2014 4:23:35 PM(UTC)
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 12/27/2013 9:07:11 AM(UTC)
Fridge and Freezer not cooling, (Refrigerator & Freezer Repair)
by jnvo 8/13/2013 4:19:21 PM(UTC)
by jnvo 8/13/2013 4:16:41 PM(UTC)
fridge and freezer not cooling sufficiently (Refrigerator & Freezer Repair)
by Frederickgee 3/12/2013 5:46:11 PM(UTC)
aaaaafridge and Freezer not cooling (Refrigerator & Freezer Repair)
by harrisdb55 10/16/2012 7:11:17 AM(UTC)
Fridge and Freezer not cooling (Refrigerator & Freezer Repair)
by chris4x4gill2 10/4/2012 6:13:38 PM(UTC)
Fridge and freezer not cooling. Fans and compressor working, possible freon leak? (Refrigerator & Freezer Repair)
by Excessumcarcer@yahoo.com 8/12/2012 1:15:41 PM(UTC)
Fridge and Freezer not Cooling properly - GE PTC22SBMARBS (Refrigerator & Freezer Repair)
by DaHadster 5/16/2012 10:19:30 AM(UTC)
by JennyM 4/24/2012 5:27:07 PM(UTC)
