Donniewade
#1 Posted : Sunday, March 19, 2017 9:03:17 AM(UTC)
Donniewade
I have a kenmore elite dryer. It stopped heating so I replaced the heating element. Still not heating so I replaced the thermal cutoff and high limit thermostat. Dryer element came on and got hot but went off after a few minutes. Cleaned the vent tube real well and put another cut off fuse and high limit thermostat and it did the same thing. I did notice the element may be getting hotter than normal because I could smell a burn smell before it shut off again. What could be causing the cutoff fuse and high limit thermostat to go out? Thanks
manfred63
#2 Posted : Sunday, March 19, 2017 8:30:35 PM(UTC)
manfred63
Hello,
First thought that comes to mind is to make sure you are using the correct replacement parts kit. What is the part number of the kit you are using? I show that for your dryer model number it should be a kit from FSP with part number 279973. If you are using a different part number kit, it likely has the wrong temperature rating, which can cause the cut out fuse to continue to blow.
Also, make sure the drum and door panel are all installed before trying to "test" the operation of the element. Running the machine without it being put together will cause the element to get too hot, since the blower will no longer be pulling air in across the element and into the drum.
Hope this helps!
Ken's Appliance Repair
PNWDrew
#3 Posted : Sunday, March 26, 2017 1:02:40 PM(UTC)
PNWDrew
Also that element will not stay on constantly, by design. It cycles on and off. Did you let it run a while to let it cycle back on?
If you are having repeat thermal cut off issues you probably have airflow issues in the venting in your house.
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore elite dryer got a thermal fuse (Dryer Repair)
by smb5769 7/9/2015 11:35:19 AM(UTC)
Kenmore Elite Dryer Intermittently Stops Running (Dryer Repair)
by CVilla 7/7/2015 9:30:28 AM(UTC)
Kenmore Elite Dryer - stops when start button released (Dryer Repair)
by bakchr 4/13/2015 11:10:30 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
kenmore elite dryer touch pad replace (Dryer Repair)
by SoCal 8/1/2014 5:03:38 PM(UTC)
Kenmore elite dryer. No heat (Dryer Repair)
by Txbigfoot 7/14/2014 10:58:25 PM(UTC)
Kenmore elite dryer (Dryer Repair)
by Lindaslats 1/19/2014 2:50:52 PM(UTC)
Erratic touchpad test results for failing Kenmore Elite Dryer (Dryer Repair)
by gmilo2 1/13/2014 5:49:01 PM(UTC)
Kenmore Elite Dryer Getting To Hot (Dryer Repair)
by TINAO 4/10/2013 10:06:52 AM(UTC)
Kenmore elite dryer wont start (Dryer Repair)
by trueblue9 12/28/2012 1:42:56 PM(UTC)
How to troubleshoot a kenmore elite dryer (Dryer Repair)
by JamesHom 7/1/2012 10:20:25 AM(UTC)
Kenmore Elite dryer time display jumps around (Dryer Repair)
by toddc 6/24/2012 7:40:54 PM(UTC)
Kenmore Elite Dryer - 3 beeps (Dishwasher Repair)
by Ken4230 3/21/2012 12:32:32 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
