MY KENMORE ELITE SMARTHEAT HE3 IS GETTING SO HOT YOU CANT EVEN TOUCH THE CLOTHES. IT IS CONSTANTLY BLOWING OUT THE HEAT SENSOR THAT HAS BEEN REPLACED AT LEAST 3 TIMES. NOT SURE WHAT TO REPAIR NEXT MAYBE THE Thermistor? ANY HELP WOULD BE APPRECIAED. I JUST CLEANED OUT ALL THE VENTS SO THERE IS NO BLOCKAGES THERE AS FAR AS I CAN TELL
A model number may help others help you. Find your model number - AppliancePartsPros.com"CONSTANTLY BLOWING OUT THE HEAT SENSOR" "NOT SURE WHAT TO REPAIR NEXT MAYBE THE Thermistor?" The heat sensor is the thermistor, so I do not know what part you are replacing. Does the unit actually change the heat output re (low, medium and high) when you chance the heat setting? FYI: I do not know if you are aware but all capitals on the net means that you are mad and are yelling. |
THIS FORUM IS DEAD!!!!!!! |
