TINAO
#1 Posted : Wednesday, April 10, 2013 10:06:52 AM(UTC)
TINAO
MY KENMORE ELITE SMARTHEAT HE3 IS GETTING SO HOT YOU CANT EVEN TOUCH THE CLOTHES. IT IS CONSTANTLY BLOWING OUT THE HEAT SENSOR THAT HAS BEEN REPLACED AT LEAST 3 TIMES. NOT SURE WHAT TO REPAIR NEXT MAYBE THE Thermistor? ANY HELP WOULD BE APPRECIAED. I JUST CLEANED OUT ALL THE VENTS SO THERE IS NO BLOCKAGES THERE AS FAR AS I CAN TELL
#2 Posted : Thursday, April 11, 2013 2:45:32 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
"CONSTANTLY BLOWING OUT THE HEAT SENSOR" "NOT SURE WHAT TO REPAIR NEXT MAYBE THE Thermistor?"
The heat sensor is the thermistor, so I do not know what part you are replacing.
Does the unit actually change the heat output re (low, medium and high) when you chance the heat setting?
FYI: I do not know if you are aware but all capitals on the net means that you are mad and are yelling.
