toddc
#1 Posted : Sunday, June 24, 2012 7:40:54 PM(UTC)
toddc
for example, for normal dry it will start at 40 minutes. when it gets to 30 minutes it skips right to 16 minutes and continues to countdown to end of cycle. does the same for delicates. starts at 35 gets to 30 and skips right 16. does this when disconnected from vent line. have changed main control board and the common thermistor. any ideas? control panel/touchpad maybe?
#2 Posted : Monday, June 25, 2012 2:32:36 PM(UTC)
That's what written in the Owner's guide:
Quote:
...A default time is displayed when an Auto Dry Cycle is selected. During the first few minutes of the drying process, the cycle time may automatically vary from the default time based on the size and fabric type of the load. Toward the end of the drying process, the estimated time display will adjust again, showing the final drying time...
