ncoles6
#1 Posted : Friday, December 23, 2016 6:32:33 PM(UTC)
ncoles6
Just brought the dryer today...will not heat up. Any ideas?
thorning
#2 Posted : Saturday, December 24, 2016 6:23:20 AM(UTC)
thorning
If the drum turns OK and you have proper electric power coming into the terminal block you most likely have a damaged or a broken wire in the heating coil. You will need to get a multimeter to test this item. Other items in the circuits may be a problem but on an electric dryer the heating coil failure is the most common problem. If you are not familiar with the wiring in an electric dryer you need to find someone who is or call a repair tech.
ThatGuy
#3 Posted : Saturday, December 24, 2016 10:44:07 AM(UTC)
ThatGuy
Groups: Expert
United States
Check your electrical connections and always use a new cord with a new dryer.
https://www.youtube.com/watch?v=HkOpPXB2jQM
UserPostedImage
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
Admiral Dryer won't heat (Dryer Repair)
by MarkMLP 11/12/2014 6:25:55 AM(UTC)
