2 Pages<12
cbmserviceguy
#11 Posted : Monday, March 28, 2016 5:00:44 AM(UTC)
cbmserviceguy
It sounds like the ignitor is bad. Use an amp meter and check the amp draw of the ignitor by clamping the meter around one of the leads to the ignitor. If the ignitor does not draw the proper amps, it will not open the gas valve. If it's getting close, but not quite, it will sometimes allow gas to seep thru the valve a bit but not ignite, which explains the smell. Hope this helps!
Kate123
#12 Posted : Monday, March 28, 2016 2:00:04 PM(UTC)
Kate123
Called the repairman he said it sounds like the gas valve So I will order one of those and hope that fixes the problem
Kate123
#13 Posted : Sunday, April 3, 2016 1:35:03 AM(UTC)
Kate123
Was told the gas valve was bad. Put new one on still doesn't work. Can't think of anything I missed. Any body have any suggestions
thorning
#14 Posted : Sunday, April 3, 2016 5:01:33 AM(UTC)
thorning
I am at a loss to suggest something more. The basics are apparently all OK ---electrical power is present to turn on the dryer , the timer is able to supply power to the drum to rotate it, the t-stats and thermal fuse are working by testing for continuity, the igniter is glowing red hot, the solenoids are being activated as evidenced by a clicking noise to allow gas flow into the burner when the igniter turns off, you said you smell gas in the burner area, but no flame. Is there any chance you have a problem with the gas flow into the dryer from the supply line ? About the only thing you did not mention is the flame sensor. However if that was not working the solenoids would not click on. I have worked on this model of Maytag dryer many times and they are very easy to diagnose problems. One thing I did find a few years ago which is not a specific problem to this model was a large wad of pipe sealant inside the line on the back end of the dryer. It had just about choked off the gas supply coming in to the valve. If I was closer I would offer to help to help solve this problem but I live in central Illinois and I am sure you do not live nearby.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Belarus chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
Admiral Dryer won't heat (Dryer Repair)
by MarkMLP 11/12/2014 6:25:55 AM(UTC)
2 Pages<12
