scv1
#1 Posted : Tuesday, December 29, 2015 7:39:54 PM(UTC)
scv1
My washer will not fill with hot water. It will on fill and work when I choose the warm or cold setting. When I choose the hot setting, the washer will not dispense hot water nor will it even work. What is causing this? Please let me know what part to replace, thank you. :confused:
sidfink43
#2 Posted : Thursday, December 31, 2015 2:39:02 PM(UTC)
sidfink43
Use a meter to see if you are getting 110v to the hot water terminal on the inlet valves when the machine is calling for hot water. If so, then the valve is defective and will not open. If not, either the timer or the temp selection switch is bad, probably the temp selection switch.
If you want to make sure the valve is ok see if you actually are getting warm water when you make that selection. If so then hot is flowing as it should and the problem is again likely in the temp selection or timer.
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
No hot water (Washer Repair)
by scv1 12/29/2015 7:41:39 PM(UTC)
No Hot Water Coming From Inlet Valve (Washer Repair)
by sophialh74 10/17/2014 5:37:11 AM(UTC)
No hot water in Maytag washer (Washer Repair)
by Pastaronie 8/16/2014 12:29:47 PM(UTC)
by arylisrandy 10/20/2013 1:35:09 PM(UTC)
No Hot Water in Washer (Washer Repair)
by Obuasi 2/8/2013 4:30:18 AM(UTC)
No Hot water (Washer Repair)
by jeschw 8/5/2012 6:19:05 AM(UTC)
No Hot Water Coming Into Washer (Washer Repair)
by chloed 2/7/2012 8:08:03 AM(UTC)
by lindaa 12/8/2011 3:39:17 PM(UTC)
maytag washer no hot water (Washer Repair)
by lindaa 12/7/2011 11:18:26 AM(UTC)
Whirlpool dishwasher has no hot water or heat for drying (Dishwasher Repair)
by ford2953 6/27/2011 5:10:33 PM(UTC)
Whirlpool Washer - No Hot Water (Washer Repair)
by jeff mitchell 5/20/2011 8:43:32 PM(UTC)
by amayesin 4/30/2011 4:03:38 AM(UTC)
Frigidaire Washer - No Hot Water (Washer Repair)
by cdWJordan 4/8/2011 12:52:49 PM(UTC)
Bosch dishwasher no hot water (Dishwasher Repair)
by samsrc 2/15/2011 7:46:00 AM(UTC)
