c00lhand
#1 Posted : Monday, August 24, 2015 10:41:31 AM(UTC)
c00lhand
washer tube is banging up and down when spin cycle disengages and brake should be stopping tube. inspected brake parts and clutch parts with no apparent defects. Should the washer drive block be squeezed onto the shaft with spanner nut. As is the drive block, spanner nut and tube all just lift out with the 7/16 bolt removed. Any suggestions!!!!!
fairbank56
#2 Posted : Monday, August 24, 2015 12:14:40 PM(UTC)
fairbank56
Groups: Expert
Yes, the drive block squeezes onto the basket drive tube with the spanner nut. Sounds like your drive block is shot. Check the condition of the two tabs at the top of the basket drive tube. If they are broke off, you will need to replace that as well.
Whirlpool 389140 Washer Drive Block - AppliancePartsPros.com
Whirlpool 285792 Basket Drive and Brake Assembly - AppliancePartsPros.com
Eric
c00lhand
#3 Posted : Monday, August 24, 2015 2:02:02 PM(UTC)
c00lhand
Thanks... ordered part.
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Kenmore 80 series washer agitating but not draining (Washer Repair)
by avai 9/8/2015 5:18:42 PM(UTC)
Kenmore 80 Series Washer problem (Washer Repair)
by castora5 4/15/2015 7:30:44 PM(UTC)
Kenmore 80 Series Washer (Washer Repair)
by DJKK 3/28/2014 1:58:23 PM(UTC)
Kenmore 80 series washer spinning problems (Washer Repair)
by dw17dw17 2/11/2014 9:53:23 AM(UTC)
Kenmore 80 series washer agitating irregularly (Washer Repair)
by fruitsnak 1/24/2014 7:59:03 PM(UTC)
kenmore 80 series washer won't drain! (Washer Repair)
by valeria 10/11/2011 3:48:53 AM(UTC)
How do you get to the lid switch on a kenmore 80 series washer (Washer Repair)
by cowboy74up 8/9/2011 3:23:53 PM(UTC)
Kenmore 80 Series Washer makes a banging noise during rinse & spin cycles (Washer Repair)
by sixnovaceks 9/30/2010 1:52:30 PM(UTC)
Kenmore 80 Series Washer Won't Spin (Dishwasher Repair)
by lbunay 9/15/2010 9:29:39 AM(UTC)
kenmore 80 series washer not agitating (Washer Repair)
by david.graham 2/25/2010 8:31:36 AM(UTC)
Kenmore 80 series washer EXPLODED!!! (Washer Repair)
by RobDingwell 8/18/2009 9:55:45 AM(UTC)
Kenmore 80 series washer not advancing automatically to 2nd rinse (Washer Repair)
by Depaneur 7/13/2008 7:02:34 PM(UTC)
