david.graham
#1 Posted : Thursday, February 25, 2010 8:31:36 AM(UTC)
david.graham
washer fills, spins, ok
in clean section agitator only spins does not agitate back and forth and makes a grating noise like gears sliping
Note. already checked the dogs and they are working fine, the noise sounds like metal gears not meshing correctly
the agitator does not turn in both directions, the dof teeth do engage
because during wash cycle it is only spinning in one direction, all the clothes get tagled tight roung the agitator
sidfink43
#2 Posted : Friday, February 26, 2010 10:26:09 AM(UTC)
sidfink43
The symptoms you describe are a bad transmission. If you can post a model number we may be able to comment further.
david.graham
#3 Posted : Friday, February 26, 2010 10:43:46 AM(UTC)
david.graham
model # 110.20802-990
david.graham
#4 Posted : Friday, February 26, 2010 10:45:08 AM(UTC)
david.graham
model # 110.20802.990
sidfink43
#5 Posted : Friday, February 26, 2010 11:30:32 AM(UTC)
sidfink43
Ok, open it up using the instructions here
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
and try to listen to pinpoint the noise in the agitation cycle. If it is coming from the transmission area it is the transmision which will have to be replaced.
