There is a problem with starting and getting it to complete a cycle, whether an automatic, or a timed. After setting the parameters and pushing the start, it does not start, or starts and drops off. If I pull out on the selector switch and nudge it a little it may start, but may only run fior a Little bit and then stop. If I continue nudging the selector switch and pushing or pulling it out a little bit it will start again. It may then complete its cycle, or require some more nudging and pushing.
Groups: Expert
