ahrjmrecr
#1 Posted : Wednesday, October 30, 2013 2:38:30 PM(UTC)
ahrjmrecr
The dryer runs fine except it doesn't produce any heat. I have replaced the Dryer Thermal Fuse. What else should I be looking at to replace?
Thanks,
Jim
#2 Posted : Wednesday, October 30, 2013 11:21:25 PM(UTC)
Parts for Whirlpool LER7646JQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
First check the power. The element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next check the heating element.
If the timer advances in an auto mode then the problem is likely with a part on the left hand side of the element (see the wiring diagram)
If the thermal cutoff is blown get back to us as there are other things you should check before replacing it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER7646.pdf (216kb) downloaded 15 time(s).
Whirlpool Electric Dryer No Heat (Dryer Repair)
by MIKEK38E 2/9/2010 5:25:07 AM(UTC)
