Steveorageous
#1 Posted : Wednesday, February 6, 2013 12:59:47 PM(UTC)
Steveorageous
Tested the Thermal Fuse- OK
Tested the Cycling Thermostat - OK
Tested the High Heat Thermostat- Ok
So, I ordered the Heating Element and installed it - No Heat?
So, I ordered the Heat limit thermostat kit and installed it - NO Heat?
So, I ordered the Thermal fuse & cycling thermostat, installed them - NO Heat???
Everything is new, My breakers appear fine...What else can I do?:(
Simon / APP Team
#2 Posted : Wednesday, February 6, 2013 2:43:37 PM(UTC)
Simon / APP Team
Groups: APP Team
First of all check if there is 240VAC to the dryer's connector block.Use the multimeter to be sure it's 240V to the dryer.
Unplug the dryer, set the timer to timed-regular, open control panel, locate the timer contacts C and A.
Remove red wire from the A and check continuity between C (BLK) - A (R).
If it's open - replace the timer
Part number: W10185982
Post the results.
Simon.
Steveorageous
#3 Posted : Saturday, February 9, 2013 4:13:11 PM(UTC)
Steveorageous
Should the red and black wires pull out easily?
I have a 4 wire harness attached to my timer?
should I pull off the entire plug or should the wire pull out of the plug?
Simon / APP Team
#4 Posted : Monday, February 11, 2013 10:32:12 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull the harness out.Remember, you are checking the timer contacts not the harness.
Simon.
