davidr222
#1 Posted : Thursday, July 31, 2014 7:01:18 AM(UTC)
davidr222
I had a small gas leak that I found was coming from the fitting that threads into the assembly that diverts gas to the oven. I think this is called the gas regulator valve. I too the fitting out and added yellow teflon tape and reinstalled. The leak was fixed. However, now the surface burner work fine but the oven won't light. I do see a glow when I try to light the oven but there is no ignition. Thanks for any suggestions you can offer.
davidr222
#2 Posted : Thursday, July 31, 2014 7:48:26 AM(UTC)
davidr222
Solved problem. When I replaced fitting the tool I used to stabilize the valve assembly inadvertently hit the off button. The button is covered by a metal part that apparently shields it from being accidentally pushed. Didn't work in my case but the cover made it difficult to see that there was a button there at all. The metal shield has to be pivoted to operate the button. I did this and the oven work fine now. Hurray! One less thing on my to-do list!
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
by fml421 6/3/2012 1:51:47 PM(UTC)
