2 Pages12>
nlcowand
#1 Posted : Thursday, February 23, 2012 10:12:41 AM(UTC)
nlcowand
My oven wont light. Everything seems to be working except the igniter wont "fire". I replaced the igniter with no change resulting. Any guidance is greatly appreciated.
joe777
#2 Posted : Friday, February 24, 2012 7:18:47 AM(UTC)
joe777
I had the same problem with my MAYTAG CWG3100AAS, I also changed a weak igniter. still no fire, then I changed the gas valve that is connected to the igniter, and walla, got fire...:) Its now working great. Good luck. check for continuity from the gas valve if u can, but they do go bad...
nlcowand
#3 Posted : Tuesday, November 19, 2013 7:07:59 AM(UTC)
nlcowand
I failed to mention that the gas valve seems to be working because I smell gas and the broiler works fine.
Appliance Ninja
#4 Posted : Tuesday, November 19, 2013 7:21:10 AM(UTC)
Appliance Ninja
You likely are not getting voltage from the control to the igniter. Do you have a meter to test voltage with?
nlcowand
#5 Posted : Tuesday, November 19, 2013 7:30:03 AM(UTC)
nlcowand
Yes I have a volt meter
nlcowand
#6 Posted : Tuesday, November 19, 2013 7:31:22 AM(UTC)
nlcowand
Appliance Ninja, thanks for reply
yes I do
Appliance Ninja
#7 Posted : Tuesday, November 19, 2013 7:32:58 AM(UTC)
Appliance Ninja
There are two wires that go to the igniter. One comes from the gas valve and one comes from the control. Can you test from the wire that comes from the control with one meter lead and the other to any metal surface (ground) for 120 VAC when the oven is set to bake, please?
nlcowand
#8 Posted : Tuesday, November 19, 2013 7:43:25 AM(UTC)
nlcowand
I only have one wire coming from the spark module to the igniter. It is not a glow plug. I feel the gas valve is fine because I do smell gas
Appliance Ninja
#9 Posted : Tuesday, November 19, 2013 7:47:09 AM(UTC)
Appliance Ninja
May I please have your model number so I am able to provide you with accurate, model specific information?
nlcowand
#10 Posted : Tuesday, November 19, 2013 7:49:47 AM(UTC)
nlcowand
Thermador PRG 366EG-01
thanks
Guest (12)
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 7:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
2 Pages12>
