arylisrandy
#1 Posted : Sunday, October 20, 2013 1:35:09 PM(UTC)
arylisrandy
When Hot temp is selected and the washer starts to fill, hot water comes into the machine for about 30 seconds then it clicks over to cold water. The hot water never comes back on and I get a tub full of cold water. I replaced the Valve Triple Water OEM (part number AP4412517) and the same thing continues to happen. I was told it was likely the Water Temp Sensor. Any other suggestions? Is there a way to test the sensor before I replace the entire board?
fairbank56
#2 Posted : Sunday, October 20, 2013 3:36:38 PM(UTC)
fairbank56
Groups: Expert
The sensor is not part of the control board, it fits into the water fill funnel. Are you filling the washer with the lid open? As a safety feature, most of these washers with electronic control will not switch from cold or warm to hot with the lid open.
GE WH12X10410 Probe Sensor Atc - AppliancePartsPros.com
Eric
arylisrandy
#3 Posted : Monday, October 21, 2013 2:19:08 PM(UTC)
arylisrandy
Eric
Thanks Eric. I haven't been opening the lid when filling. I'll try replacing the sensor.
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
No hot water (Washer Repair)
by scv1 12/29/2015 7:41:39 PM(UTC)
by scv1 12/29/2015 7:39:54 PM(UTC)
No Hot Water Coming From Inlet Valve (Washer Repair)
by sophialh74 10/17/2014 5:37:11 AM(UTC)
No hot water in Maytag washer (Washer Repair)
by Pastaronie 8/16/2014 12:29:47 PM(UTC)
No Hot Water in Washer (Washer Repair)
by Obuasi 2/8/2013 4:30:18 AM(UTC)
No Hot water (Washer Repair)
by jeschw 8/5/2012 6:19:05 AM(UTC)
No Hot Water Coming Into Washer (Washer Repair)
by chloed 2/7/2012 8:08:03 AM(UTC)
by lindaa 12/8/2011 3:39:17 PM(UTC)
maytag washer no hot water (Washer Repair)
by lindaa 12/7/2011 11:18:26 AM(UTC)
Whirlpool dishwasher has no hot water or heat for drying (Dishwasher Repair)
by ford2953 6/27/2011 5:10:33 PM(UTC)
Whirlpool Washer - No Hot Water (Washer Repair)
Belarus jeff mitchell 5/20/2011 8:43:32 PM(UTC)
by amayesin 4/30/2011 4:03:38 AM(UTC)
Frigidaire Washer - No Hot Water (Washer Repair)
by cdWJordan 4/8/2011 12:52:49 PM(UTC)
Bosch dishwasher no hot water (Dishwasher Repair)
by samsrc 2/15/2011 7:46:00 AM(UTC)
