2 Pages12>
jrnutpaul
#1 Posted : Friday, September 20, 2013 8:31:58 AM(UTC)
jrnutpaul
Yesterday, after drying one load correctly the dryer stopped heating. Everything else seems fine, just no heat
#2 Posted : Friday, September 20, 2013 9:59:40 AM(UTC)
Parts for Maytag MDE6800AYQ Dryer - AppliancePartsPros.com
First check the power.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK, the next thing to check is the heating element.
Unplug the unit.
Measure across the heater element should be around 10 ohms.
It is a good idea to disconnect one side of the heater when measuring. This ensures that you do not read an alternate/parallel circuit path.
jrnutpaul
#3 Posted : Friday, September 20, 2013 11:11:24 AM(UTC)
jrnutpaul
Thermostates read 0
coil reads 12
L1 and L2 combinations are correct both at the panel and the strip
JulesLamers
#4 Posted : Friday, September 20, 2013 9:29:31 PM(UTC)
JulesLamers
Something's up with the rotor i wonder.
#5 Posted : Saturday, September 21, 2013 2:34:21 AM(UTC)
Here is a manual.
http://appliancejunk.com...e&id=67;t=1379757841
You will have to join the site to download the manual.
The manual is a biot confusing because it covers many units.
The wiring diagram for this unit is on page 10-27.
Check from the control board (heater output) (PU_44) to motor (1) (BK_33).
Should be 12 ohms.
If it is then the problem is either the heater relay is not closing or the centrifugal switch is not closing or you have a bad connection/wire.
Check the thermistor, should be around 10,000 ohms at room temperature,
Try running the diagnostics , page 9-12.
If all the above are OK, you could try unplugging the unit and shorting across the heater relay contacts (PU_44 to BK_43) at the control board.
Then plug the unit in and give it a try.
If you now have heat then it is probably a control board problem, either the board is not closing the heater relay or the relay contacts are shot.
If there is no heat then the probable cause is the centrifugal switch on the motor. Either the switch is shot or the mechanism that activates the switch is not working.
jrnutpaul
#6 Posted : Sunday, September 22, 2013 9:05:15 AM(UTC)
jrnutpaul
thanks for the help...burnt wire from the high limit to the coil insulator. Runs fine now
#7 Posted : Monday, September 23, 2013 2:46:08 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
jrnutpaul
#8 Posted : Monday, September 23, 2013 8:23:09 AM(UTC)
jrnutpaul
Yesterday, working with Denman, I found the problem with the dryer (MDE6800AYQ) It was a burnt wire from the hi limit switch to the heater coil insulator. So, today I did a load. The dryer temperature was too hot. Maybe there's a reason the wire burnt. I checked the ohms across the hi-limit switch with my meter set at 200 and got a reading of 4.0, the same reading I get when I short the meter leads. Is the hi-limit switch supposed to be closed?:rolleyes:
#9 Posted : Monday, September 23, 2013 9:38:46 AM(UTC)
Yes it should be closed at room temperature.
Unplug the unit and check your heating coil.
it is a good idea to disconnect at least one side of it just to be sure that you do not read an alternate/parallel circuit.
it should be around 8 to 12 ohms.
Then check from each heater connector to the case/frame both should be infinite ohms (open)
If not the coil is grounded and should be replaced.
Next would be to check the thermistor resistance.
jrnutpaul
#10 Posted : Monday, September 23, 2013 9:47:22 AM(UTC)
jrnutpaul
OK I'll do that next. The thermister is open, both hi-limit switches read 4.0 and both thermal fuses read 4.0
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 10/8/2011 4:12:13 PM(UTC)
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 5/16/2011 8:58:46 AM(UTC)
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 4/6/2011 6:53:41 AM(UTC)
Help...my dryer stopped heating (Dryer Repair)
by BDGD 12/3/2010 12:47:30 PM(UTC)
by Tcon 10/17/2010 6:22:21 AM(UTC)
by jstayoung1 6/10/2010 12:37:53 AM(UTC)
by jstayoung1 6/10/2010 12:21:32 AM(UTC)
by atciskanik 3/3/2010 4:32:59 AM(UTC)
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 1/18/2010 5:39:07 AM(UTC)
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 9/5/2009 7:33:29 AM(UTC)
GE Elec stackable dryer stopped heating (Dryer Repair)
by arbiggs 4/21/2009 11:23:47 AM(UTC)
2 Pages12>
