willow5000
#1 Posted : Wednesday, September 24, 2014 1:48:01 PM(UTC)
willow5000
Old dryer, but replaced the heating element about 5-6 months ago.
It was always very strong and bright. Sometimes I worried that it was too strong, but it's a dryer.
All of a sudden, it's not heating. Opened the bottom panel up, and it is definitely not heating up (as in not getting that orange glow it used to).
Before I take it apart, I would like to know what are the options.
Obviously, one is that the heating element is broken somewhere (oh, joy!!!:mad: )
But I would like to know if there are any other (read - less expensive) options.
What else could be causing this? fuses? something else? what else should I check?
Thanks in advance - you guys are always awesome! :D
#2 Posted : Friday, September 26, 2014 1:56:56 AM(UTC)
Parts for Kenmore Dryer 11063012101 - AppliancePartsPros.com
If you go to the Sears parts site they have part breakdown diagrams which they do not share with other vendors.
See the attachment for your wiring diagram.
There are lots of possible causes for no heat.
First I would check the power to the unit. The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next unplug the unit and check the heating element with a meter.
If OK then check the thermostats.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
63012101.pdf (278kb) downloaded 5 time(s).
