kimyoung
#1 Posted : Monday, May 16, 2011 8:58:46 AM(UTC)
kimyoung
I'm trying to determine what part I would need to replace on a Whirlpool Estate dryer that will not heat. Also, after determining the part I need, how much technical expertise is needed to replace the part? Are the instructions fairly basic?
Thanks.
KY
:confused:
#2 Posted : Tuesday, May 17, 2011 3:45:53 AM(UTC)
Replacement parts for WHIRLPOOL TEDL640DQ1 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
No heat can be a number of things: power, heating coil blown, open thermostat/thermal cut-off, timer contacts or the motors centrifugal switch.
I listed them in the order they should be checked.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The motor etc run off of 120 volts but the heating coil requires 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
The heating coil, thermostats, high limit cut-off and the timer contacts can be checked with the unit unplugged using ohms. This is much safer than messing with the unit plugged in.
If the thermal cut-off is blown get back to us as there are other things that should be checked before replacing it.
Cannot really say how much technical expertise is required.
Here is a good link with basic dryer repair info.
http://www.applianceaid.com/dryers.html
Also there are lots of videos on Yahoo.
Your unit is made by Whirlpool.
File Attachment(s):
TEDL640.pdf (126kb) downloaded 14 time(s).
