2 Pages12>
jrnutpaul
#1 Posted : 12 years ago
jrnutpaul
Yesterday, after drying one load correctly the dryer stopped heating. Everything else seems fine, just no heat
#2 Posted : 12 years ago
Parts for Maytag MDE6800AYQ Dryer - AppliancePartsPros.com
First check the power.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK, the next thing to check is the heating element.
Unplug the unit.
Measure across the heater element should be around 10 ohms.
It is a good idea to disconnect one side of the heater when measuring. This ensures that you do not read an alternate/parallel circuit path.
jrnutpaul
#3 Posted : 12 years ago
jrnutpaul
Thermostates read 0
coil reads 12
L1 and L2 combinations are correct both at the panel and the strip
JulesLamers
#4 Posted : 12 years ago
JulesLamers
Something's up with the rotor i wonder.
#5 Posted : 12 years ago
Here is a manual.
http://appliancejunk.com...e&id=67;t=1379757841
You will have to join the site to download the manual.
The manual is a biot confusing because it covers many units.
The wiring diagram for this unit is on page 10-27.
Check from the control board (heater output) (PU_44) to motor (1) (BK_33).
Should be 12 ohms.
If it is then the problem is either the heater relay is not closing or the centrifugal switch is not closing or you have a bad connection/wire.
Check the thermistor, should be around 10,000 ohms at room temperature,
Try running the diagnostics , page 9-12.
If all the above are OK, you could try unplugging the unit and shorting across the heater relay contacts (PU_44 to BK_43) at the control board.
Then plug the unit in and give it a try.
If you now have heat then it is probably a control board problem, either the board is not closing the heater relay or the relay contacts are shot.
If there is no heat then the probable cause is the centrifugal switch on the motor. Either the switch is shot or the mechanism that activates the switch is not working.
jrnutpaul
#6 Posted : 12 years ago
jrnutpaul
thanks for the help...burnt wire from the high limit to the coil insulator. Runs fine now
#7 Posted : 12 years ago
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
jrnutpaul
#8 Posted : 12 years ago
jrnutpaul
Yesterday, working with Denman, I found the problem with the dryer (MDE6800AYQ) It was a burnt wire from the hi limit switch to the heater coil insulator. So, today I did a load. The dryer temperature was too hot. Maybe there's a reason the wire burnt. I checked the ohms across the hi-limit switch with my meter set at 200 and got a reading of 4.0, the same reading I get when I short the meter leads. Is the hi-limit switch supposed to be closed?:rolleyes:
#9 Posted : 12 years ago
Yes it should be closed at room temperature.
Unplug the unit and check your heating coil.
it is a good idea to disconnect at least one side of it just to be sure that you do not read an alternate/parallel circuit.
it should be around 8 to 12 ohms.
Then check from each heater connector to the case/frame both should be infinite ohms (open)
If not the coil is grounded and should be replaced.
Next would be to check the thermistor resistance.
jrnutpaul
#10 Posted : 12 years ago
jrnutpaul
OK I'll do that next. The thermister is open, both hi-limit switches read 4.0 and both thermal fuses read 4.0
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 4 years ago
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 11 years ago
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 11 years ago
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 12 years ago
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 13 years ago
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 14 years ago
GE dryer stopped heating but dryer still works (Dryer Repair)
by picker1 14 years ago
Help...my dryer stopped heating (Dryer Repair)
by BDGD 14 years ago
by Tcon 14 years ago
by jstayoung1 15 years ago
by atciskanik 15 years ago
whirlpool gas dryer stopped heating what could be the problem (Dryer Repair)
by Lacey14 15 years ago
Admiral Dryer Stopped Heating. Why? (Dryer Repair)
by kelso1 16 years ago
GE Elec stackable dryer stopped heating (Dryer Repair)
by arbiggs 16 years ago
2 Pages12>
