hoffa28
#1 Posted : Sunday, September 1, 2013 10:10:03 PM(UTC)
hoffa28
Hello, I started the wash and all seemed fine. Came back after I thought it was done and lifted the lid and was full of water. The dial looks like it ran through all cycles as it was on the off position. No matter what cycle I put it on nothing happens, but the timer just clicks and continues through the cycles. As it gets to rinse you hear it for a split second try to do something and stops and the timer continues on.
Thank you for the help.
fairbank56
#2 Posted : Monday, September 2, 2013 6:43:40 AM(UTC)
fairbank56
Groups: Expert
Can't find the wiring diagram for this washer. Open the control panel and provide a clear photo of the wiring diagram which should be either folded up inside the control panel or pasted to the inside of the back panel on the left side inside control panel.
Eric
hoffa28
#3 Posted : Monday, September 2, 2013 12:07:42 PM(UTC)
hoffa28
Is this picture the right one?
hoffa28 attached the following image(s):
fairbank56
#4 Posted : Monday, September 2, 2013 1:08:09 PM(UTC)
fairbank56
Groups: Expert
Yes, it's very blurry but that's ok, I found the diagram elsewhere. I would check the connections at the motor. You will need to remove the cabinet. Unplug the motor connector, check for corroded/burnt wires/terminals, also check wires/terminals at the motor overload switch. You may have an open neutral at the motor. This would allow the washer to fill and timer to run but no power to motor.
Eric
Cabinet removal: Cabinet removing Whirlpool direct drive washer - YouTube
Motor overload switch:
UserPostedImage
Lid switch or timer? (Washer Repair)
by ToledoJD 7/23/2016 3:52:29 PM(UTC)
Where is the defrost timer? (Refrigerator & Freezer Repair)
by dalekbrooks 9/10/2015 7:34:42 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
Whirpool Estate..Bad Timer? (Washer Repair)
by APPLIANCEDUDE1972 9/20/2014 9:11:27 PM(UTC)
GE Dryer - Motor or Timer? (Dryer Repair)
by mwatson2 12/28/2013 1:01:20 PM(UTC)
by jtvolk 10/11/2013 5:36:23 PM(UTC)
Defrost timer? (Refrigerator & Freezer Repair)
by gunnerferg 10/10/2013 5:46:56 AM(UTC)
Does this have a defrost timer? (Refrigerator & Freezer Repair)
by boylan 11/2/2012 10:11:55 AM(UTC)
Kenmore Elite - motor or timer? Help! (Washer Repair)
by flenn 10/27/2012 5:06:22 PM(UTC)
GE Profile Timer? (Washer Repair)
by rjledoux 9/2/2012 1:41:15 PM(UTC)
How to disable defrost timer? (Refrigerator & Freezer Repair)
by mokhubi 8/13/2012 12:54:23 PM(UTC)
Faulty timer?? (Dryer Repair)
by pullmyfinger 2/20/2012 5:29:52 AM(UTC)
How to replace oven clock/timer? (Oven Repair (including Ranges and Cooktops))
by aec393 12/15/2011 11:46:50 AM(UTC)
Bad timer? (Washer Repair)
by george248 10/31/2011 7:37:23 AM(UTC)
Where is my defrost timer? (Refrigerator & Freezer Repair)
by evan_w 10/20/2011 6:43:57 PM(UTC)
