jadendy
#1 Posted : Sunday, April 26, 2009 1:19:56 PM(UTC)
jadendy
Our dryer started to make a horrible screeching rattling noise and my husband decided it had to do with the drum seal and replaced that. Now when we tried to use it, it make a rattling noise, not constant but like more, less, more, less - rhythmic. He sent me online to try to find a schematic or parts diagram, but I can't find anything anywhere. What could be causing the rattle and where can I find a parts diagram? Thanks!:rolleyes:
jadendy
#2 Posted : Sunday, April 26, 2009 9:01:14 PM(UTC)
jadendy
The sound is coming from inside the dryer (drum area), not the top area and is pretty loud. How could the timer cause this?
#3 Posted : Monday, April 27, 2009 12:55:18 AM(UTC)
Here is a wiring diagram for you.
https://www.servicematters.com/d...0Sheet%20-%203979710.pdf
Here are parts breakdowns
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=6EpO5Mc9GxZhFDGt+tkRUg**.shcapp3305?modelNumber=11065922401&pop=flush
It will not be the timer.
Check that the blades inside the drum are tight.
A rattle is often the rear support rollers. Check that the rubber roller itself is OK and that the bearing/shafts are OK. Also check that the drum surface where the rollers ride is clean and that the drum is not cracked.
Screeching is often the idler roller, front glides or the motor's bearings.
But by the sound of where the noise is coming from (back,rear,bottom) I would put my money on the support rollers.
Guest (4)
Samsung DMT300RFW Dishwasher Rattling Noise (with video link) (Dishwasher Repair)
by Guest 8/9/2021 11:52:56 AM(UTC)
Samsung dryer making rattling noise (Dryer Repair)
by Bigwill63 10/6/2016 5:40:06 PM(UTC)
Dryer won't tumble, loud rattling noise (Dryer Repair)
by wenahs 10/19/2015 3:37:20 PM(UTC)
Loud Rattling Noises (FAN?) in KitchenAid Double wall oven (Oven Repair (including Ranges and Cooktops))
by curbalertband 6/27/2014 12:35:19 PM(UTC)
Kenmore Model 110 Rattling Noise (Washer Repair)
by DrFeelgood 9/4/2013 11:03:02 AM(UTC)
Shaking/rattling noise for LG electric dryer (Dryer Repair)
by forgop 7/22/2013 11:46:07 AM(UTC)
Rattling noise on agitate (Washer Repair)
by JCBsWasherisbreaking 6/23/2013 11:18:12 PM(UTC)
Compressor Rattling noise? (Refrigerator & Freezer Repair)
by buddha131 11/11/2012 6:54:08 AM(UTC)
Rattling noise (recording of sound) (Dryer Repair)
by nswords34 11/7/2012 6:19:52 AM(UTC)
Dryer making loud Buzzing and rattling noise (Dryer Repair)
by lmorris2026 7/13/2012 5:26:34 AM(UTC)
Freezer Rattling noise (Refrigerator & Freezer Repair)
by feanor387 4/1/2010 8:04:25 PM(UTC)
Maytag stackable washer dryer makes rattling noise (Dryer Repair)
by anniesmomrocks 7/29/2009 1:40:58 PM(UTC)
No Heat and Rattling Noise (Dryer Repair)
by pak21 6/12/2009 9:03:10 AM(UTC)
Whirlpool Duet - rattling noise during spin (Washer Repair)
by mhcraig 3/12/2009 4:27:10 PM(UTC)
Rattling noise in Maytag dishwasher (Dryer Repair)
by xxxbowl300 12/18/2008 7:41:15 AM(UTC)
