jadendy
#1 Posted : 16 years ago
jadendy
Our dryer started to make a horrible screeching rattling noise and my husband decided it had to do with the drum seal and replaced that. Now when we tried to use it, it make a rattling noise, not constant but like more, less, more, less - rhythmic. He sent me online to try to find a schematic or parts diagram, but I can't find anything anywhere. What could be causing the rattle and where can I find a parts diagram? Thanks!:rolleyes:
jadendy
#2 Posted : 16 years ago
jadendy
The sound is coming from inside the dryer (drum area), not the top area and is pretty loud. How could the timer cause this?
#3 Posted : 16 years ago
Here is a wiring diagram for you.
https://www.servicematters.com/d...0Sheet%20-%203979710.pdf
Here are parts breakdowns
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=6EpO5Mc9GxZhFDGt+tkRUg**.shcapp3305?modelNumber=11065922401&pop=flush
It will not be the timer.
Check that the blades inside the drum are tight.
A rattle is often the rear support rollers. Check that the rubber roller itself is OK and that the bearing/shafts are OK. Also check that the drum surface where the rollers ride is clean and that the drum is not cracked.
Screeching is often the idler roller, front glides or the motor's bearings.
But by the sound of where the noise is coming from (back,rear,bottom) I would put my money on the support rollers.
Samsung DMT300RFW Dishwasher Rattling Noise (with video link) (Dishwasher Repair)
by Guest 4 years ago
Samsung dryer making rattling noise (Dryer Repair)
by Bigwill63 8 years ago
Dryer won't tumble, loud rattling noise (Dryer Repair)
by wenahs 9 years ago
Loud Rattling Noises (FAN?) in KitchenAid Double wall oven (Oven Repair (including Ranges and Cooktops))
by curbalertband 11 years ago
Kenmore Model 110 Rattling Noise (Washer Repair)
by DrFeelgood 12 years ago
Shaking/rattling noise for LG electric dryer (Dryer Repair)
by forgop 12 years ago
Rattling noise on agitate (Washer Repair)
by JCBsWasherisbreaking 12 years ago
Compressor Rattling noise? (Refrigerator & Freezer Repair)
by buddha131 12 years ago
Rattling noise (recording of sound) (Dryer Repair)
by nswords34 12 years ago
Dryer making loud Buzzing and rattling noise (Dryer Repair)
by lmorris2026 13 years ago
Freezer Rattling noise (Refrigerator & Freezer Repair)
by feanor387 15 years ago
Maytag stackable washer dryer makes rattling noise (Dryer Repair)
by anniesmomrocks 16 years ago
No Heat and Rattling Noise (Dryer Repair)
by pak21 16 years ago
Whirlpool Duet - rattling noise during spin (Washer Repair)
by mhcraig 16 years ago
Rattling noise in Maytag dishwasher (Dryer Repair)
by xxxbowl300 16 years ago
