2 Pages12>
mike145
#1 Posted : Tuesday, June 25, 2013 5:11:49 PM(UTC)
mike145
Put a new light fixture in our laundry room today and turned the breaker off in the process. Afterwards the wife wanted to run a load through the washer. Now all of the sudden the spin, and agitate will not function. The LED on the motor blinks on for 1 second an off for 1 second. I did the reset by unplugging it, waiting 2 min, and open close the door 6 times, and still no spin or agitate. Light still blinked on/off 1 sec each, also blinked the same wen put in spin cycle. I cannot figure this out for the life of me. Any help would be great, Thanks.
tbn3
#2 Posted : Wednesday, June 26, 2013 3:20:34 PM(UTC)
tbn3
Do you have fault display light?
If not, do you know how to turn selector knob in order to manually get codes!
May need to be calibrated again once power was shut off.
Let me know about the display & manual code selection & if you need them I'll give them to you. I have Whirlpool model WRW5550XW0 without display light so had to bring mine up manually.
Mine wouldn't spin or agitate!
mike145
#3 Posted : Wednesday, June 26, 2013 3:36:57 PM(UTC)
mike145
There is no display, just the light on the motor. How do i re calibrate it?
Mike
mike145
#4 Posted : Wednesday, June 26, 2013 3:38:23 PM(UTC)
mike145
I figured out how to put it in field service mode, but not sure what to do once it is in the service mode.
fairbank56
#5 Posted : Friday, June 28, 2013 5:11:59 AM(UTC)
fairbank56
Groups: Expert
In field service mode, place it in spin test. On the rightmost connector of the motor inverter board, check DC voltage between the violet wire and red wire, should be 0 volts, violet and yellow 0 volts, violet and blue 12 volts, violet and black 12 volts. If your not getting the correct voltages, the control board behind the user control panel is faulty.
Eric
mike145
#6 Posted : Friday, June 28, 2013 5:20:30 AM(UTC)
mike145
Ill try right now and post back.
mike145
#7 Posted : Friday, June 28, 2013 5:31:47 AM(UTC)
mike145
I am getting no reading through any of them. In service mode while in the spin position it just drains.
fairbank56
#8 Posted : Friday, June 28, 2013 6:02:50 AM(UTC)
fairbank56
Groups: Expert
The drain pump should not be operating while in service mode spin test. When you first go into service mode, rotate the selector 9 clicks clockwise to get to spin test. Then check the voltages.
Eric
mike145
#9 Posted : Friday, June 28, 2013 6:12:19 AM(UTC)
mike145
in field service mode, on the 9th click the drai pump kicks on and bigins to drain. Not getting voltage on any connectors.
fairbank56
#10 Posted : Friday, June 28, 2013 6:24:14 AM(UTC)
fairbank56
Groups: Expert
Ok, according to my data, the 4th click should be hot water, 5th-cold water, 6th-slow agitate, 7th-fast agitate, 8th-pump, 9th-spin. It may be that the drain pump remains on during spin test, I don't remember. Sounds like you have a faulty control board. If you get a board from APP, you can return it if it doesn't work. You must transfer the model select plug from the old board to the new one before installing. It's the plug on the board that has one or two jumper wires on it.
GE WH12X10439 Board Asm Mounted - AppliancePartsPros.com
Eric
If you want to check voltages for the other modes, here's the procedure.
UserPostedImage
Guest (5)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
Estate Washer will not agitate or spin (Washer Repair)
by Greenday1827 7/19/2013 12:34:47 PM(UTC)
Kenmore washer will not agitate or spin (Washer Repair)
by dlacacres 5/8/2013 9:46:24 AM(UTC)
GE washer will not agitate or spin (Washer Repair)
by st smith 4/1/2013 7:11:12 AM(UTC)
Newer GE Washer will not agitate or spin (Washer Repair)
by dwolfe 9/11/2012 8:34:44 AM(UTC)
my washer will not agitate or spin (Washer Repair)
by angelsthree 5/3/2012 5:49:18 AM(UTC)
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
Maytag Washer will not agitate or spin (Washer Repair)
by Mbat4 2/13/2012 3:12:24 PM(UTC)
by wpatetec 12/19/2011 4:45:27 PM(UTC)
Motor Hums But Washer Will Not Agitate Or Spin (Washer Repair)
by john@ljolson.com 10/22/2011 12:14:27 PM(UTC)
Crosley washer will not agitate or spin. (Washer Repair)
by Jinxd66 4/14/2011 4:54:38 AM(UTC)
2 Pages12>
