Mbat4
#1 Posted : 13 years ago
Mbat4
Maytag washer will fill to the proper level then stop. It will not start the cycle. I turned the dial to the spin cycle to spin and drain but that does not work as well. I purchase a lid switch and installed it but no change to the problem. What is the next step? Any advice would be helpful. :confused:
sidfink43
#2 Posted : 13 years ago
sidfink43
That should have fixed things. Check the fuse and if it is ok then try by-passing the switch to rule it in or out.
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 13 years ago
