2 Pages<12
eisehunter
#11 Posted : Sunday, June 2, 2013 1:14:59 PM(UTC)
eisehunter
So from L1 to 4M you got 0 ohms but from L1 to 5M it was infinite ohms.
Is this correct? Yes.
bad motor, ok, thanks for all your help
eisehunter
#12 Posted : Sunday, June 2, 2013 1:15:11 PM(UTC)
eisehunter
eisehunter
#13 Posted : Tuesday, June 4, 2013 4:36:22 PM(UTC)
eisehunter
Which two lead/terminals on the motor to apply 120v directly to check when motor disconnected from dryer?
#14 Posted : Tuesday, June 4, 2013 11:00:49 PM(UTC)
4M to 5M
These connect in the start and main (run)windings.
When the motor gets close to operating speed the centrifugal switch opens.
Disconnecting the start winding but leaving the main winding in circuit.
eisehunter
#15 Posted : Wednesday, June 5, 2013 7:43:35 AM(UTC)
eisehunter
So 4m ground and 5m 120V?
#16 Posted : Wednesday, June 5, 2013 8:17:02 AM(UTC)
Polarity does not matter.
eisehunter
#17 Posted : Sunday, June 9, 2013 11:26:48 AM(UTC)
eisehunter
Put power directly to 4m and 5m and motor works fine. Hooked back up motor to dryer harness and won't start. Must be timer?
eisehunter
#18 Posted : Sunday, June 9, 2013 11:38:22 AM(UTC)
eisehunter
Put power directly to 4m and 5m and motor works fine, hook back up dryer wiring harness and it wont start, thinking bad timer?
#19 Posted : Sunday, June 9, 2013 12:46:06 PM(UTC)
Could be the timer.
I do not understand what is going on here as your meter readings showed the motor as an open circuit.
eisehunter
#20 Posted : Sunday, June 30, 2013 8:27:26 AM(UTC)
eisehunter
Changed timer, solved the problem. Excellent start circuit checkout directions.
Thanks!!
Guest (4)
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 6/8/2022 5:45:29 AM(UTC)
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 9/26/2018 9:11:22 AM(UTC)
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 10/8/2017 9:57:09 AM(UTC)
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 3/21/2015 9:53:19 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
whirlpool electric dryer (Dryer Repair)
by ajlgap19 6/6/2014 9:55:32 AM(UTC)
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 1/23/2014 7:03:27 PM(UTC)
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 1/16/2014 9:02:04 AM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 2/6/2013 12:59:47 PM(UTC)
Whirlpool Electric Dryer (Dryer Repair)
by mayork 11/14/2012 10:21:04 AM(UTC)
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 9/10/2012 2:08:11 PM(UTC)
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 8/20/2012 12:48:36 PM(UTC)
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 8/18/2012 1:10:17 PM(UTC)
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 5/16/2012 12:36:00 PM(UTC)
2 Pages<12
