2 Pages<12
eisehunter
#11 Posted : 12 years ago
eisehunter
So from L1 to 4M you got 0 ohms but from L1 to 5M it was infinite ohms.
Is this correct? Yes.
bad motor, ok, thanks for all your help
eisehunter
#12 Posted : 12 years ago
eisehunter
eisehunter
#13 Posted : 12 years ago
eisehunter
Which two lead/terminals on the motor to apply 120v directly to check when motor disconnected from dryer?
#14 Posted : 12 years ago
4M to 5M
These connect in the start and main (run)windings.
When the motor gets close to operating speed the centrifugal switch opens.
Disconnecting the start winding but leaving the main winding in circuit.
eisehunter
#15 Posted : 12 years ago
eisehunter
So 4m ground and 5m 120V?
#16 Posted : 12 years ago
Polarity does not matter.
eisehunter
#17 Posted : 12 years ago
eisehunter
Put power directly to 4m and 5m and motor works fine. Hooked back up motor to dryer harness and won't start. Must be timer?
eisehunter
#18 Posted : 12 years ago
eisehunter
Put power directly to 4m and 5m and motor works fine, hook back up dryer wiring harness and it wont start, thinking bad timer?
#19 Posted : 12 years ago
Could be the timer.
I do not understand what is going on here as your meter readings showed the motor as an open circuit.
eisehunter
#20 Posted : 12 years ago
eisehunter
Changed timer, solved the problem. Excellent start circuit checkout directions.
Thanks!!
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 3 years ago
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 6 years ago
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 7 years ago
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 10 years ago
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 10 years ago
whirlpool electric dryer (Dryer Repair)
by ajlgap19 11 years ago
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 11 years ago
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 11 years ago
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 11 years ago
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 12 years ago
Whirlpool Electric Dryer (Dryer Repair)
by mayork 12 years ago
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 12 years ago
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 13 years ago
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 13 years ago
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 13 years ago
2 Pages<12
