fixitgood
#1 Posted : Sunday, December 9, 2007 1:17:15 PM(UTC)
fixitgood
Stopped cooling/freezing, found evap coil clogged with lint, cleaned but no help, fan running -no comp
thxs
#2 Posted : Monday, December 10, 2007 3:30:33 AM(UTC)
Go to the back of fridg and remove motherboard cover. Turn off power and remove J8,J9, J11 common connector. Stick a jumper wire in connector pins J11 and J8, plug in fridg, compressor should run. If so, replace motherboard and evaporator fan and thermistor. If no run, pry off the start relay from the side of the compressor and order a new one. If you have a meter it would help to confirm voltage to the compressor.
Good luck on this sorry excuse for a fridg.
fixitgood
#3 Posted : Thursday, December 13, 2007 2:05:35 PM(UTC)
fixitgood
Hi Richappy:
Thanks for your reply. I did what you said and jumpered J8 and J11 and the compressor started to run. Its pretty quiet so I put my hand on it and could feel it running. Also checked for power at the comp and it was zero. Both fans are running so would I still have to replace the evap fan?
Thanks a bunch
York
fixitgood
#4 Posted : Thursday, December 13, 2007 2:09:13 PM(UTC)
fixitgood
Also made a error on my first post saying the evaporator was clogged with lint. Should have said condensor.
Thxs
#5 Posted : Thursday, December 13, 2007 3:39:51 PM(UTC)
All indications point to a bad mother board. They recommend replacing the board and the evaporator/thermistor, comes as a kit.
Good luck.
fixitgood
#6 Posted : Thursday, December 13, 2007 5:34:09 PM(UTC)
fixitgood
Hi :
The parts diagram shows the evap fan motor w/o the thermister. Which one would I have to replace? Do you have a number for the kit?
Appreciate the help
York
Simmer Burners on Thermador Range Stopped Working (Oven Repair (including Ranges and Cooktops))
by Guest 12/1/2021 3:15:27 PM(UTC)
My Range stopped working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Eternalsnshine 10/25/2016 12:17:59 PM(UTC)
Range stopped working (Oven Repair (including Ranges and Cooktops))
by Bigmikeq71 10/14/2015 9:37:35 PM(UTC)
by Bigmikeq71 10/14/2015 9:36:36 PM(UTC)
Fridge stopped working (Refrigerator & Freezer Repair)
by SaskGuy 8/4/2014 3:38:54 PM(UTC)
Fridge stopped working.Cntl pnl lit as "-" (Refrigerator & Freezer Repair)
by Jerry Conice 7/31/2014 12:41:01 AM(UTC)
by Mikebl5 8/23/2013 1:56:58 PM(UTC)
GE GSL25JFPABS Frezer/Fridge Stopped working (Refrigerator & Freezer Repair)
by mrs9693nj 3/26/2013 6:57:50 AM(UTC)
Frigidaire Range Stopped working (Oven Repair (including Ranges and Cooktops))
by callii 11/4/2010 5:17:55 PM(UTC)
Ice maker Hotpoint Fridge stopped working (Refrigerator & Freezer Repair)
by djgolf 10/31/2010 12:40:33 PM(UTC)
Maytag Fridge Stopped Working (Refrigerator & Freezer Repair)
by dkrobinson 1/13/2010 9:23:03 PM(UTC)
Roper electric range stopped working (Oven Repair (including Ranges and Cooktops))
by D Dorey 1/9/2010 7:30:12 AM(UTC)
