2 Pages<12
Simon / APP Team
#11 Posted : Monday, April 22, 2013 11:01:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Steve.
Please describe (no offense) how do you check the voltage at the ignitor.
Simon.
SteveDB
#12 Posted : Monday, April 22, 2013 1:00:32 PM(UTC)
SteveDB
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi, Steve.
Simon.
insert each probe into machine side plug, after setting meter to voltage, turn machine on, obtained reading of 123v, as instructed by certified tech on phone.
Simon / APP Team
#13 Posted : Monday, April 22, 2013 1:25:12 PM(UTC)
Simon / APP Team
Groups: APP Team
In that case you need to replace the ignitor. If there is 120 VAC at the plug and you put in a good ignitor it should glow!
Simon.
SteveDB
#14 Posted: : Monday, April 22, 2013 1:31:02 PM(UTC)
SteveDB
Simon.
hi Simon.
I just bought it Friday, it arrived Saturday, and I installed it shortly after it arrived. I called back when I realized it still wasn't working.
SteveDB
#15 Posted : Thursday, April 25, 2013 3:09:46 PM(UTC)
SteveDB
Ok, well, this issue is resolved! I hope.
It appears that the dryer control board had a bad component. Of course, as I am not an electronic circuitry guy, I have no way of repairing it. Grrr!
Soldering isn't the issue, it's figuring out which one is bad.
thorning
#16 Posted : Thursday, August 22, 2013 3:58:15 PM(UTC)
thorning
Steve DB
I have a similar problem. No heat --the ignitor does not glow --nothing. No gas flow--Fuses all appear to be OK. Gas valve does not open to allow gas to flow . What else can be checked.??? What did you find on your unit that was the problem ? Need help.
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Kitchenaid dryer doesn't heat (Dryer Repair)
by Snakebone 11/8/2012 11:40:23 AM(UTC)
by Snakebone 11/8/2012 11:31:10 AM(UTC)
Maytag Neptune-Dryer doesn't heat up (Dryer Repair)
by See Jane Run! 7/24/2012 3:27:30 PM(UTC)
Dryer doesn't heat properly. (Dryer Repair)
by pnoe 2/19/2012 1:18:10 PM(UTC)
by Sandysalter 10/29/2011 2:41:21 PM(UTC)
Dryer doesn't heat (Dryer Repair)
by jammaker 5/11/2011 7:59:33 AM(UTC)
Maytag Neptune Gas dryer doesn't heat (Dishwasher Repair)
by kmc1214 4/8/2011 8:00:44 AM(UTC)
Anana Dryer Doesn't Heat (Dryer Repair)
by dhs51 2/8/2011 3:26:11 PM(UTC)
Electric Dryer Doesn't heat up (Dryer Repair)
by yomeropistolero 1/16/2011 9:57:44 PM(UTC)
Dryer doesn't heat properly (Dryer Repair)
by kevin.m.elkin@rrd.com 12/7/2010 7:41:41 PM(UTC)
by briggins8 10/9/2010 3:48:45 PM(UTC)
Gas Dryer doesn't heat up - but that isn't my issue (Dryer Repair)
by mitch8 10/6/2010 11:04:27 AM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
2 Pages<12
