briggins8
#1 Posted : Saturday, October 9, 2010 3:48:45 PM(UTC)
briggins8
The dryer spins but doesn't produce heat and all the lights on the front flash from time to time.:mad:
#2 Posted : Saturday, October 16, 2010 4:16:28 AM(UTC)
Replacement parts for FRIGIDAIRE AEQ7000EG0 Frigidaire/dryer | AppliancePartsPros.com
Here is the tech sheet for this unit
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf
And a service manual
http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf
Try unplugging the unit for 5 minutes or so to see if it will reset.
Try running the diagnostics.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Dryer doesn't heat (Dryer Repair)
by SteveDB 4/16/2013 10:47:38 AM(UTC)
Kitchenaid dryer doesn't heat (Dryer Repair)
by Snakebone 11/8/2012 11:40:23 AM(UTC)
by Snakebone 11/8/2012 11:31:10 AM(UTC)
Maytag Neptune-Dryer doesn't heat up (Dryer Repair)
by See Jane Run! 7/24/2012 3:27:30 PM(UTC)
Dryer doesn't heat properly. (Dryer Repair)
by pnoe 2/19/2012 1:18:10 PM(UTC)
by Sandysalter 10/29/2011 2:41:21 PM(UTC)
by jammaker 5/11/2011 7:59:33 AM(UTC)
Maytag Neptune Gas dryer doesn't heat (Dishwasher Repair)
by kmc1214 4/8/2011 8:00:44 AM(UTC)
Anana Dryer Doesn't Heat (Dryer Repair)
by dhs51 2/8/2011 3:26:11 PM(UTC)
Electric Dryer Doesn't heat up (Dryer Repair)
by yomeropistolero 1/16/2011 9:57:44 PM(UTC)
Dryer doesn't heat properly (Dryer Repair)
by kevin.m.elkin@rrd.com 12/7/2010 7:41:41 PM(UTC)
Gas Dryer doesn't heat up - but that isn't my issue (Dryer Repair)
by mitch8 10/6/2010 11:04:27 AM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
