25 Pages«<1920212223>»
#201 Posted : Tuesday, March 5, 2013 11:21:17 AM(UTC)
Looks like you are on the right track and the new water valve should fix the problem.
rrnworks
#202 Posted : Sunday, March 17, 2013 10:40:08 AM(UTC)
rrnworks
Try to raise it to at least -5°F. What is the temperature in the refrigerator?
Fridge is 38 degrees F (temp control on 2). I have the freezer temp control all the way off (to the left of 1). I also noticed the freezer defrost cycle continues to work. I can find very little official information that lists a "too cold" freezer causing an ice make to stop working?
I did test the voltage straight from the icemaker molex connector (with the icemaker disconnected) across the black and white wires - and only read 40 Volts? It's not clear if this needs to always be 120 Volts?
Besides a bad replacement ice maker, the only other solution I can see worth trying is to replace the thermostat / control board or the damper assembly? If I set the refrigerator temperature control to off, it does shut off the compressor.
#203 Posted : Monday, March 18, 2013 1:07:48 PM(UTC)
Follow the instructions posted by richappy in one of our previous threads: http://forum.appliancepartspros...cemaker-inoperative.html and post the results.
rrnworks
#204 Posted : Tuesday, March 19, 2013 5:22:21 PM(UTC)
rrnworks
Hi Gene,
I ordered 'another' replacement ice maker unit, put it in, and it is already making ice after a couple hours. So it does seem like my first idea was right - the first new replacement ice maker was bad after all.
Chris
#205 Posted : Tuesday, March 19, 2013 5:50:12 PM(UTC)
Hi Chris,
Unfortunately I see it more and more often. We can not rely on a new parts any more. Thank you for the feedback. I'm glad to hear it's up and running.
rrnworks
#206 Posted : Tuesday, March 19, 2013 7:33:03 PM(UTC)
rrnworks
Hi Chris,
Thank you Gene - I've learned so much from you and feel like I'm now at least an "ice maker" repair expert. :) I'm attaching two other helpful document I discovered which covers all three areas (icemaker, motor, and optics).
File Attachment(s):
In%20Door%20Ice%20Manual%20with%20Diagram.pdf (8,639kb) downloaded 58 time(s).
Modual Ice Maker Diagnostic Sheet.pdf (1,365kb) downloaded 49 time(s).
#207 Posted : Wednesday, March 20, 2013 12:50:43 PM(UTC)
Thank you for sharing with us these documents. It can be useful for people with not working ice makers.
Thanks again and good luck with your refrigerator.
jewels74
#208 Posted : Tuesday, April 16, 2013 4:07:25 AM(UTC)
jewels74
I have a kitchenaid refrigerator with an ice maker that is only making about 8 cubes of ice a day. The prongs that push the ice out are in the down position and the ice tray is full. So, it seems they are not cycling through and pushing the ice out when they are suppose to. I took the ice maker out and took it apart. There is nothing that looks wrong. All of the gears appear to move and the sensor lights are doing what they are suppose to. I do not have a voltage tester.
When I put the ice maker back together and turned it on, the prongs came up and it made one batch of ice. Then, this morning, the prongs are back in the down position, stuck in the ice.
Any suggestions? What should I replace?
Thank you,
Jewels74
#209 Posted : Tuesday, April 16, 2013 11:33:11 AM(UTC)
Hello,
What is the complete model number of the refrigerator?
jewels74
#210 Posted : Tuesday, April 16, 2013 12:03:03 PM(UTC)
jewels74
Sorry, the refrigerator is a kitchen aid,
KSCS23INSS00
Thanks for the quick reply.
Jewel 74
Guest (7)
