Altevon
#1 Posted : Thursday, January 31, 2013 10:35:09 PM(UTC)
Altevon
Whirlpool Electric Range Model # GY398LXPT00, Serial # XR5107443
I can not Bake, Broil, Auto Clean, set Temperature or set Cook Time.
The top cooking element work fine.
The clock and display work.
The oven light turns on/off
The buttons on the left half of the Touch pad do not work, i.e.:
Convect Bake: No
Bake: No
Custom Broil: No
Temp +/_ No
Auto Clean: No
Cook Time: No
The buttons on the right half of the Touchpad do work.
I can not Bake, Broil, Auto Clean, set Temperature or Cook Time.
However, I can preheat the oven when I press Stop Time-, than Start button.
Oven goes through PreHeat cycle to 350 deg F, booth element work. I can stop this cycle by pressing Off/Cancel.
Thank you for your help and suggestions,
Altevon
#2 Posted : Friday, February 1, 2013 2:13:12 AM(UTC)
Parts for Whirlpool GY398LXPT00 Range - AppliancePartsPros.com
The problem could be the control panel (keypad) or the electronic control (timer).
The usual way to troubleshoot this is to check the keypad outputs and if they are OK then replace the timer. But I cannot find info on the actual keypad outputs so unless you have some experience troubleshooting keypads this will not be an option.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If this does nothing then pretty well all you can do is take a gamble on one of the parts.
File Attachment(s):
GY398.pdf (402kb) downloaded 7 time(s).
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
